Signal Conditioning
Another signal "gain" question...
I recently asked a question on if a signal's gain can be determined or not. Henrik did a great job of kindly replying to my previous post, but I'm still in need of some help if possible 🙂
Here is a more detailed introduction to the problem. Signals were collected on a load cell with potentially various gains. I am attempting to find out which one was used...but struggling! I am attempting to solve this problem in LabVIEW. Please help.
Here is a PDF of the amplifier used, with information regarding the potential gains used:
https://www.biopac.com/wp-content/uploads/DA100C.pdf
A gain of 1000 should have been used, but we are concerned this was altered without out knowing.
I have attached four text files as examples (sampling rate: 2kHz). As some of this is just over my head, I am struggling to find a solution.
Thank you all for any help you can provide.
Best,
Millionhorns
(3,380 Views)
I tried to read some values , one seems to be without second signal ...
here are my plots, I calculatet a ratio of some sort of mean amplitude value maybe you can find some sort of correlation to the ratios of possible gain  50/200/1000/5000
plots.pngto estinate possible settings much more information about your setup and what kind of information you are looking at would be needed.....
a measurement that isn't well documented was never done 😞
Greetings from Germany
Henrik
LV since v3.1
(3,351 Views)
