01-21-2018 06:17 AM
Please help me to find a PWM solution ( evaluation boards /power module) with this caracteristics :
- control/adjust frequencies from software
- feeadback option /spectrum analyzer to find resonance frequency
-3 channels with difrent frequencies (42.8 KHz, 21.4 KHz and 10.7 KHz )
- Adjustable Duty cycle /pulse with 2.5%,5%, 10% , fall time <=20nS
-Up to 500 Watt
01-21-2018 02:06 PM
From your picture, I would go with a AWG if 4 levels should be possible,
or a simple digital output ...
followed by a line driver , depending on the needed output power (and maybe a comperator as preamp)
If you try to create the PWMs with three 555 your phase will be unknown.. (OK, it's possible to oscillate them in sync... but why do that if software can do it much better 😉 )
