SAPHIR - Toolkits Discussions
Owning Library has blocked execution
I am using SAPHIR G data base tool kit to push the data to SQL DB. But when i try to run vi, It through the Owning Library has blocked execution . Kindly help me on this.
(5,646 Views)
This error could have many origins. I need more information to help you to fix this issue.
  1. When you start LabVIEW, does the tool (Tools >> SAPHIR >> GDataBase for MySQL >> MySQLdatabase viewer) is working fine ?
  2. If you create a blank project, add a new VI with open and close functions with all required input, does it work or not ?
Looking forward to your answer.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(5,617 Views)
I also has the same error.
When selecting MySQLDatabaseViewer the GUI popsup and disappers.
Your second option also I tried. But it has same error
This VI's owning library has some problem. The library has blocked the VIs that it owns from executing until the problem is resolved. Please see errors listed on the library.
Please help
(4,838 Views)
