Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
11-22-2023 05:37 AM - edited 11-22-2023 06:01 AM
Hi Olivier,
Sorry for joining the discussion so late, I'm not sure if you are still active on this project.
I'm really keen to use the ViBox enum history probe and I get no issues when installing as mentioned by others.
I just don't get any Saphir history probe option added to the menu regardless of data type (screenshot attached).
Could you, or anyone else, suggest a fix for this?
I'm using LV2021.
Edited to add; I get the correct right click menu to create the enum probe in the project window as per the instructions and the VIs appear to run without error.
Thanks in advance.
Paul.
11-22-2023 08:34 AM
Hi Paul,
I'm sorry, but I'm not working anymore at SAPHIR. I can't help with that 😓
11-22-2023 09:14 AM
Hi Oliver,
Thanks for the quick reply, no problem at all 😁.
I have actually now found a slightly clumsy workaround. The custom probe has actually been created but just not added to the right click menu. If you create a new custom probe manually but base it on the Saphir one in the custom probe folder then it works!
Cheers, Paul.
11-23-2023 01:54 AM
Hi Paul,
Have you noticed that the probes are now open source, as a few other of our toolkits ?
You can find it at : QMT / open-source projects / Probes · GitLab
Fork it and improve it as you wish ! 🙂
