06-18-2015 05:34 AM
THe powerpoint for the talk I delivered on a scope control application based around asynchronously running "sub scopes" and a sub panel in a main UI vi.
Please note that one of the technical challanges I said I had trouble with - entering values below 6 digits of precision in a Ring Properties dialog box has been kindly solved by Keith Dumbell. He has shown that if you set the display type to Scientific then you can easily set small values.
06-18-2015 05:48 AM
Here is the image that I cannot get to display in the first post.
06-20-2015 02:48 AM
I like the DVR-of-a-Subpanel idea; I'm stealing that.
