I have trouble when writing a binary file. Here is what I do:
I have some VI's collecting various data for a fixed period of time. I put all the data into 1D arrays at a fixed frequency (they all have the same size). Once it is done I merge all the arrays into one 2D array and I write that to a binary file. If I wait about 10 seconds after writing the file and I repeat the whole thing, everything is fine and the timing is correct. If I wait for a shorter period of time (say a sec, and this is the maximum I can wait to have a usable application) then the timing is wrong in the first part of the loop (the time-critical data-acquisition one). Of course, if I don't write the file, everything is fine (I have to wait about 250 msec between two runs, but that's ok). Any advice ?
I also tried several things like streaming the data to disk during the time-critical period and this works fine only if the file allready exists. If not I experience jitters again. I don't really want to stream the data in real time, but it could work if I can get rid of the jitters. Again, any advice ?
I'm using LV7.1 and the real time module running on a PC (ETS).
Another, sort of related, topic: I noticed that when using 2D arrays within time critical loops all the process are slowdown whereas if I use several 1D arrays everything is fine... Any idea why ?
Laurent
