Hi, again,
I'm sorry, I might be misunderstanding the problem then. So, can you create the webpage correctly, copy the html to the RT system (is it PXI or FP?) and then access it? Then, do you get this error when you try to connect to the HTML page in the RT system from a Web Browser? Finally, which system do you have to restart to have access again: the RT system or the computer? From the error that you are getting, one quick thing you could try is to change the port number the web server is using, as it was recommended before. If you could detail step by step what you are doing to get this error message, it will help me a lot.
Thanks and have a great day!
GValdes
