I am using BNC-2120 to do the timing things, first I generate a anolog pulse whose falling edge is going to trigger another pulse which is digital to be genrated, and then the third pulse will be generated at the second pulse' falling edge. I found there was some sub-second delay when I get the second pulse, it's very serious because all the actins should be finished at microsecond level. Is there any solution to do the timing not using the computers' clock since there are only two internal clock on the BNC-2120, but I need one more?
