Dear all,
Is there some software/hardware that allows a PC running Windows 2000
or similar which is connected to an ethernet private LAN and it is only
listening to put a timestamp with a 50 microseconds accuracy to each
frame received. I guess the timestamp should be put by the ethernet
adapter. And using a LV RT operative system.
Is there some ethernet adapter that puts timestamps to received frames
and keeps the data and timestamp in some buffer until the operative
system reads the data and timestamp for the last XX frames.
If someone could put some light in the solution It would be great.
Miguel
