sbRIO-9651 eth1 nondefault PHY
sbRIO-9651 supports secondary ethernet port eth1 via external PHY usage which is KSZ9031MNXIA. Is it possible to use another 1GBE PHY, DP83867 for example with MDI register access on Linux RT level? Can uboot and/or linux RT drivers be modified to do so?
Thanks!
(1,608 Views)
Hey Crowbar,
could you explain more of your project and what your goals are? It's be helpful to have some context with this question
(1,582 Views)
I want to use another PHY which supports PTP (IEEE 1588) on a HW level, default PHY doesn't.
(1,536 Views)
I haven't found an example of another person doing this. What are you trying to synchronize with the sbRIO via PTP?
(1,512 Views)
