Hi Yogece,
http://www.ni.com/gettingstarted/ should have relevant information on how to get started, configure, and begin programming your sbRIO-9642. This tutorial discusses several different products from NI. When the tutorials discuss hardware and ask you to choose what you are using, select CompactRIO. From the software perspective, CompactRIO and Single-Board RIO are the same. The primary difference is the mechanical form factor.
Hope this helps,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
