sbRIO 9607 POE Damage?
Customer send FortiSwitch Rugged POE switches to be used on a system. The intent to replace existing unmanaged, non POE switched in the system that was up and running without issue.
FortiSwitch Rugged is powered with 24VDC - they should not support POE with voltage, per the spec sheet.
One component in the system uses a sbRIO 9607, since making the change to the FortiSwitch(es) I cannot communicate with it (ModbusTCP).
That is, if it is plugged directly into the FortiSwitch - No Link LED, no ping, zilch (multiple cables tried).
If I put a plain jane unmanaged switch between the sbRIO device and the FortiSwitch: Link LED, Ping, ModbusTCP all good.
It's baffling.
(1,407 Views)
Edit: Moar better English...
Customer sent some FortiSwitch Rugged POE switches to be used on a system. The intent is to replace existing unmanaged, non POE switches in the system that was up and running without issue.
FortiSwitch Rugged is powered with 24VDC - they should not support POE with that voltage, per the spec sheet.
(1,386 Views)
