sbRIO 9606 configuration problem. Real time module not recognized.
Dear all,
I have a problem with configuration of my target (sbRIO 9606). I have installed Labview 2020 student version with all required  modules for this target:
1) LabVIEW Real-Time Module 2020
2) LabVIEW FPGA Module 2020
3) NI-RIO 20.0
When i connect target to power supply 24Vdc first green LED diode is on and power supply is ok. Second Yellow LED diode is blinking twice every few seconds, and i found in target manual this:
So, i tried installing software on my remote system in NI MAX, as follows:
And i get this ERROR. I have installed Real Time module 2020 but i do not know why it is not recognized.
Also, I tried this at my older Labveiw version  2017 and had a same problem. This target worked fine some time ago, but I quess upgrading a software was interrupted and since then this problem is boddering us.
I hope you can help me.
Thank you
(1,094 Views)
Accepted by topic author luka_stanic
Hello
have a look at this page and select your target sb-RIO-9606:
Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT - NI
The highest LabVIEW-version that supports that target is LabVIEW 2019 SP1 - you will not have any succes with any LabVIEW 2020 edition.
Regards, Jens
Kudos are welcome...
(1,041 Views)
Hello
Thank you Jens, that was an issue. I installed LabVIEW 2019 SP1 and now it is working.
Jens
(1,034 Views)
