‘sbRIO-9223’ analog input module comparability with CompactRIO Single-Board Controller (sbRIO-9627)
I want to connect the ‘sbRIO-9223’ analog input module with CompactRIO Single-Board Controller (sbRIO-9627), initially seems that everything is ok but ‘CompactRIO Single-Board Controller Module Compatibility’ table (http://www.ni.com/product-documentation/54495/en/) doesn’t contain the ‘sbRIO-9223’ entry.
Kindly confirm that is ‘sbRIO-9223’ analog input module compatible with CompactRIO Single-Board Controller (sbRIO-9627)?
(175 Views)
Hi leadstechnology,
That module will be compatible with the sbRIO 9627. Generally with C Series modules and sbRIOs, you'll just want to make sure you have the 'sbRIO version' of it (without the metal casing) and that you sbRIO controller supports C series modules.
Using a CompactRIO Single-Board Controller (sbRIO) with C-Series Modules
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kKitSAE&l=en-US
Jiwhan S.
Technical Support Engineer
(61 Views)
