read from tdms on realtime
I'm using the example code of "TDMS-ContAcq-IntClk.c" from the "DAQmx ANSI C"
My question is how can I read and analyze the data on realtime and on offline.
any example code will help me alot, thanks!
My setup information:
Hardware: NI 9234
NI-Daqmx: device driver 9.4.0f5
Windows version: XP
Language: Qt (C++)
(3,699 Views)
Hi simon27,
Are you limited to c code or can you do you have the option of using labview also?
Could you tell me a little more about your real-time setup also? Is it a PXI or RT PC? What cards will you be using and what will you be trying to do?
In order to run text-based code on a PXI it sounds like you might want to be looking towards the CVI Real-Time module, which creates a dll that is deployed to the RT OS.
Jesse Dennis
Engineer
INTP
(3,681 Views)
