05-13-2019 09:20 AM
Hi, i am working with a LabView 2017 and CRIO9082 with 2 modules 9208 and 9425. Also I use the 2 port Rs232 and RS485. Working with the IDE of LabView, all run perfect. And Works OK. Now my problem it is that I set to run at startup the the application and when CRIO start nothing happen.
I attach the main VI of RT CRIO. You could see that there is a Led toggle of 1sec, before anything start. Application never reach that point.
Also there is a vi that log each step. Never write into the disk.
I try doing a dummy application with the same configuration, that read from FPGA a digital input and send it to RT and HMI with Network Variable, and works fine with Run at startup.
So I read that in max there is and option to see a Error Log. And this option give and error that couldn't establish communication with CRIO.
I don't know what to do now to find the trouble. One thing that i could try , (but will be very slow) it is erase by turn a VI and try if work in that way.
If there is a way to debug this will be very helpful.
05-14-2019 08:04 AM
Well doing the last debug, I found in the error log some bug.
This one appears using a VI from an example that turn on and off the user LED of CRIO.
#### #Date: Mon, May 13, 2019 3:17:04 PM #OSName: PharLap ETS 13.1 #OSVers: 13.1 #OSBuild: 257 #AppName: PH_EXEC_SMP #Version: 17.0 32-bit #AppKind: AppLib #AppModDate: #LabVIEW Base Address: 0x015A90D0 LVRT.DLL load address: 0x0249B000 InitExecSystem() call to GetCurrProcessNumProcessors() reports: 2 processors InitExecSystem() call to GetNumProcessors() reports: 2 processors InitExecSystem() will use: 2 processors starting LabVIEW Execution System 2 Thread 0 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 1 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 2 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 3 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 4 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 5 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 6 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] starting LabVIEW Execution System 2 Thread 7 , capacity: 24 at [3640612625.46786550, (15:17:05.467865468 2019:05:13)] VI_BROKEN (0): [VI "NI_Real-Time Target Support.lvlib:RT LEDs.vi" (0x04454110)] VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI_Real-Time Target Support.lvlib:RT LEDs.vi" (0x04454110)] this->flags=50471424, compilerError=6 VI_BROKEN (0): [VI "NI_Real-Time Target Support.lvlib:RT board LEDs.vi" (0x04f02020)] VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI_Real-Time Target Support.lvlib:RT board LEDs.vi" (0x04f02020)] this->flags=50471424, compilerError=6
This one come from a VI that I use to save a log file. This VI comes from an example of Boiler
#### #Date: Mon, May 13, 2019 2:37:24 PM #OSName: PharLap ETS 13.1 #OSVers: 13.1 #OSBuild: 257 #AppName: PH_EXEC_SMP #Version: 17.0 32-bit #AppKind: AppLib #AppModDate: #LabVIEW Base Address: 0x015A90F0 LVRT.DLL load address: 0x0249B000 InitExecSystem() call to GetCurrProcessNumProcessors() reports: 2 processors InitExecSystem() call to GetNumProcessors() reports: 2 processors InitExecSystem() will use: 2 processors starting LabVIEW Execution System 2 Thread 0 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 1 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 2 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 3 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 4 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 5 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 6 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] starting LabVIEW Execution System 2 Thread 7 , capacity: 24 at [3640610246.09587530, (14:37:26.095875264 2019:05:13)] VI_BROKEN (0): [VI "NI_FileType.lvlib:LVFileType.ctl" (0x04ff1cd0)] VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI_FileType.lvlib:LVFileType.ctl" (0x04ff1cd0)] this->flags=34611712, compilerError=6 VI_BROKEN (0): [VI "NI_FileType.lvlib:FT_FileTypes.ctl" (0x050c3f90)] VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI_FileType.lvlib:FT_FileTypes.ctl" (0x050c3f90)] this->flags=34611712, compilerError=6 VI_BROKEN (0): [VI "NI_FileType.lvlib:Is File an LLB.vi" (0x050c1770)] VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI_FileType.lvlib:Is File an LLB.vi" (0x050c1770)] this->flags=33563136, compilerError=6 VI_BROKEN (0): [VI "NI_FileType.lvlib:Get File Type.vi" (0x04b230d0)] VirtualInstrument::SetOrClearBadVILibrary - now VI is bad on [VI "NI_FileType.lvlib:Get File Type.vi" (0x04b230d0)] this->flags=33563136, compilerError=6
For now i will try to take out this VI. To see if there is other error. Because with the bug of file, the C-RIO9082 freeze.
If anyone has a suggestion will be very appreciated.
05-15-2019 08:23 AM - edited 05-15-2019 08:25 AM
Yesterday at end , I need to eliminate the VI that make a log. Because that one hang the RT. I attached the VI.
I don't understand why this library has problem, also I don't understand why only fail inside the CRIO. Because working from computer all is OK.
NI_FileType.lvlib
I will made a log with TDMS, this is working with the data.
If someone know a workaround to fix the problem with library, will be nice
