11-01-2009 10:39 AM
I am working on a project in sbrio 9462.
I am unable to work the sbrio standalone. how do i do that?
i can configure the ports and all using the real time project!! but i dunoo how to make the sbrio standalone. anybody please help.
11-01-2009 09:35 PM
11-01-2009 11:26 PM
Yes i have made a project using the real time project wizard its working with the ethernet cable connected. I just need to know how i can blink an led stand alone! i want it urgent because of one deadline coming up . Thank you!
11-02-2009 12:07 AM
You didn't answer my question. You will need to create an executable and then you can configure it to run at startup. Have you followed these steps:
Building a Stand-Alone Real-Time Application (RT Module)
Running a Stand-Alone Real-Time Application (RT Module)
06-03-2014 02:06 PM
Hi.... I have a doubt for example I have a microphone conected to sbrio 9631 by a NI 9234 but the problem is that I have to use the NI sound and vibration to acquire Db(A) of the noise. I would like to know if I can use the NI sound and vibration to create a stand-alone aplication to measure the db(A) with the microphone 40 p.h. because when I am developing an aplicaion en the FPGA I can´t use the toolkit NI sound and vibration.
