01-16-2011 02:54 AM
I created a VI on my SBRIO 9632 board. But, whenever I try to run it a
compile
error comes up that says -
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying Practice Project 1.lvproj
Deploying SBRIO-9632-Tsakalis(
01-17-2011 01:55 PM
Hi Ashfaque,
The error you're seeing is most likely because the VI uses the Control Design and Simulation module, but that module is not installed on your Single-Board RIO. This KnowledgeBase article has some relevant information: Failed to Load Shared Library NILVSim.* on a Real-Time Target Device.
You should be able to fix the problem by using the Measurement & Automation Explorer (MAX) to install the Control Design and Simulation module onto your Real-time controller. Please reference this article for instructions on how to do so: Installing Software on Real-Time (RT) Series PXI Hardware. Although that KnowledgeBase is about PXI controllers, you can install the Single-Board RIO software the same way.
Morgan S
01-17-2011 03:18 PM
Thank you so much for the reply Morgan. It was a big help.
01-17-2011 04:58 PM
I am still having one more problem. Now I can build and download the application to the SBRIO board but immediately after the download an error shows up saying that communications with the board has been disconnected. Then I have to go back to project explorer, right cilck on the board and click connect to see the results. Is that natural? if not, how can I fix it? Thanks in advance for your help
