Reply
kit rio is not communicating with my PC running windows 10
the Hardware NI sbRIO-9637 can't connect to my PC running windows 10.
the error code is in the picture i attached.
othmen
(258 Views)
Have you tried resetting the sbRIO by holding down the reset button, as shown in the error image you attached? I would also make sure that NI System Configuration software is installed on your sbRIO. See here for instructions on how to install software to your real-time system.
Is this your first time using the sbRIO? Do you know if it's successfully connected in the past?
Francine P.
Applications Engineering
(238 Views)
Try turning OFF Windows firewall and any Anti-virus software...it could be blocking the port.
(197 Views)
