i have an SBRIO system with an isolated power supply
http://www.ni.com/pdf/manuals/375052c.pdf
on page 15 , it says all ground connections AI, AO, D GND are internally connected to earth ground lug,
is the power connector J3's negative terminal also connected to earth ground internally ?
i have a system assembled on a aluminuim enclosure which has the earth ground connection , and also the power supply that is used to power the sbrio gives out isolated voltage, but now if the J3 power connector's negative terminal has internal connection with the holes and ground lug, how can i use my isolated power supply whose negative terminal is not connected to the earth ground, its main AC power supply has the earth ground connection not the DC output.
i am unable to open the sbrio board from my system at this time to check directly.
can some one please help if the J3 power onnector's negative -ve terminal is internally connected to the ground lug and mounting holes.
