initializing a BSTR in a .dll for TCP/IP
Hello Everyone!
I'm trying to establish a TCP/IP connection between my computer and an external computer controlling a laser device. The sw on the laser only understands TLV commands and to send them over I have to use a .dll that I have to initialize in LabVIEW, but everytime I try, the wizard says that the BSTR type symbols cannot be defined. I tried to use a preprocessor definition but LabVIEW won't accept it (maybe I used the wrong one?) I also tried to 'fake' the structure of a BSTR and send it to the node but that didn't take either.
I'm pretty new to LabVIEW and I have no experience in programming C or C++.
Does anybody know a preprocessor definition I could try? Or some other solution?
Thanks in advance,
A desperate, soon to be, programmer
(2,136 Views)
Hello TimVanDriessche
Have you seen this document?
Or you can contact with the laser manufacturer.
__________________________________________
The best way to thank, is to give KUDOS
(2,004 Views)
Hello VA.KI,
Thank you for the reply! I've seen the article before though.
I figured out a correct conversion without using the .dll. It turns out I can build the correct command without a BSTR.
Thank you for your time though! 🙂
Tim
(1,990 Views)
Good Day Tim,
I am in the exact same situation as you were. I need to communicate with a laser - a Trumark laser, through TCP/IP. I am also not sure how to define BSTR when using the Import Shared Library Wizard
How did you manage to solve this? If you are communicating with a Trumark laser, are you willing to share your vis?
Thank you,
Shaun
(1,941 Views)
