07-29-2008 05:13 PM
08-11-2008 10:05 AM
08-12-2008 11:18 AM
08-14-2008 09:55 AM
Hi Thang,
From the LabVIEW DSC Module Help, "Shared variables of data types other than double, Boolean, and U32 bit field have no alarm states based on shared variable value." For other shared variables, "Bad Status" is the only alarm that can be set. Additional details are in the Help topic Supported Shared Variable Types (DSC Module).
If you want to set alarms for the numeric and Boolean values, you will want to separate them from the cluster and array.
