Hi
I am having a serious problem, We have a gas chromatogram(GC). It supports serial communication.
Before going into the problem, I want to tell you that I'm using crio 9012 controller. I having NI 9870 serial port module.
So getting to the problem, I have connected the GC to the serial port. If I write "BS" command to the serial port, the GC will respond to it by Sending around 80,048 bytes of data.
Now what I need to do is Skip the first 10 bytes and divide the rest of the bytes(80,040) into sets of 8. ie., I need to have 10,000 sets of data each having 8 bytes in it.
The reason why I need to do this is because after the first 10 bytes, I need only the 4th,5th & 6th byte of the next 8 bytes to follow. I have to collect this data from all the 10000 sets.
Also I need to know whether it is a good idea to store the data in 10000 sets and then process it is possible,If so how to implement it or what are the other ideas i can use.
Kindly help me out..
Temin
