11-22-2018 06:06 AM
what is the major specification differentiate CRIO 9035,9045 & 9047.which one will give flexible programming support.
11-24-2018 08:29 AM
Just looking at the quick specifications, I see the cRIO-9045 has more RAM than the cRIO-9035. Everything else is basically the same. But the cRIO-904x series added support for DAQmx on the RT instead of being forced to write your own FPGA or the Scan Engine. Then the cRIO-9047 is a pretty major upgrade over the cRIO-9045 (double the RAM, faster processor clock, more processor cores, wider temperature range). But is the $1.6k worth it for your application?
So based on the applications I have done, I would lean to using the cRIO-9045.
