how can i use two channels to show different voltages in DAQ ?
my problem is that when i choose different channels to read the outputs from my sensors, it ignores the channels which i have choosen 0 or 1 and it puts 0 channel only for both sensors. and the result is one same reading at both output guages, one reading is steady and the other is fluctuating. how can i make it recognize each one differently, is the proplem at my programme ? help me please
(2,827 Views)
Greetings,
AI Waveform Scan.vi and AI Sample Channel.vi each have a Channel(s) input. You do not have anything wired to these inputs. By default, these inputs are both Channel 0. You should wire "0" to one of these inputs and "1" to the other.
Good luck with your application.
Spencer S.
(2,827 Views)
