12-30-2008 03:52 AM
Hi.. I am using pci5640r fpga card...i want to design a filter in fpga..for that i designed the filter in the host and generated fpga code for that, using ' labview fpga code ' block...(since filter designing itself is not directly supported in fpga).but i want to do upsampling after the filtering...that also to be done in fpga..but the upsampling block is not supported in fpga vi...that is available only in the host vi...so what should we do?
kindly reply if anyone knows
thanks...
12-31-2008 06:20 PM
Well, whatever is not supported on the FPGA VI will not work directly. You will have to find a way to work around it and, if are not able to, then transfer the data points to the host and perform the analysis over there. Have a look at the examples that are provided in the example finder and go through this article which talks about ways in which you can transfer data between the FPGA and host VI:
01-09-2009 12:11 AM
01-09-2009 12:32 AM
01-12-2009 10:15 PM
thanks very much...
