From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
error code 2147220308 when first use of NI sb rio 9632
Our lab bought NI sb rio 9632 by 2012. I am trying to make the robot works for the first time.
According to the "Quick Start Guide", once the robot is connected to the computer, the "National Instruments Robotics Hardware Setup" (New robotics Project Wizard) starts automatically. But This is not what happened with my robot. So I opened  "National Instruments Robotics Hardware Setup" by my self. The setup stops at step 5 (test step) and it announces the following error (error code = 2147220308) :
nisyscfg.lvlib:Uninstall All.vi:1<APPEND>
<b>Complete call chain:</b>
Install all available SW.vi
Wizard.vi
Message 1 of 9
(6,137 Views)
I noticed that no software has been installed
So when I tried to install some softwares, this was not possible. (I ignore the reason), it tells me that this operation or function is not supported
Please can someone help me to resolve these troubleshooting ?
Thanks in advance
Message 2 of 9
(6,126 Views)
Hello hakemass,
The document below provides an explaining for the error you are receiving as well as some troubleshooting steps. I would recommend walking through the proposed solution.
Error -2147220308 When Running NI Robotics Hardware Setup Wizard:
http://digital.ni.com/public.nsf/allkb/3D00C9C862F01CEC86257943004F9EBA
j_bou
Message 3 of 9
(6,098 Views)
Hello and thanks for your response.
I did follow the link that you gave me:
and it is said that two possible reasons may cause this problem.
1. The first is something to do with IP adress, I choose to use static IP adress :
http://digital.ni.com/public.nsf/allkb/37C790309A210A748625757000570938
This is what I did to force a certain IP adress :
2. The sencond is what I think the case, because the status led (fourth led) flashes twice every couple seconds. This indicates that the device has detected an error in its software. So I tried to install some softwares following the link below :
http://digital.ni.com/public.nsf/allkb/2BAD2D3A7DE25EB2862576D6007EDB22?OpenDocument
But I can't do all steps and I ignore the reason. This is what I get when I try to follow the steps in the previous link :
Any one has an idea about the trouble I am getting ? Otherwise can someone give me the email adress to contact National instrument ?
Thanks in advance
Message 4 of 9
(6,081 Views)
This the phone of national instrument, but I can't reach them  Smiley Sad
Message 5 of 9
(6,079 Views)
This the phone of national instrument +961-1-646 111 , but I can't reach them  Smiley Sad
Message 6 of 9
(6,078 Views)
Hello hakemass,
National Instruments customer service number is 1 (800) 531-5066. The customer service representative will route you to an Applications Engineer if you have SSP.
You should not have to chage the IP address of your computer in most cases. You need to make sure that the IP address of your sbRIO is in the same subnet as your computer. In addition, based on your screenshot, you computer seems to have the same IP address as your sbRIO. You need to choose a different IP address under the same subnet as your computer for the sbRIO.
Configure Your CompactRIO System for First Use:
http://www.ni.com/getting-started/set-up-hardware/compactrio/first-use
Why Does My CompactRIO Controller or Single-Board RIO Not Show Up in Measurement & Automation Explorer (MAX)?:
http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42
J_bou
Message 7 of 9
(6,056 Views)
thanks for your reply,
I followed the link you gave me, and DHCP or local link.
and the system status is : connected and no software is installed.
when I tried to add software by right clicking on software, I still have the same problem, it says that the time is out and that I have to check whether my robot is on-line:
is this due to the fact that I don't have NI-RIO CD ?
but NI-RIO appears in MAX :
do you have any idea about the reason that stop software add ?
Thanks in advance
Message 8 of 9
(6,023 Views)
Do you know if the NI software you installed came from a DVD? If that is the case then the process will expect to find the media from that same location. Do you know if someone in there might have acess to this DVD?
In case that's not an option, you could try downloading the NI-RIO driver, and using it as the source of the file installation.
Message 9 of 9
(5,967 Views)
