09-30-2008 10:17 AM
hello , all of you...
congratulations for this forum
i'm from Greece and i don t write very well english ..so i want you to know it.
my problem is that i want to represent Volt and Current from one electrologic box
i do this measure with sensors and save data to a PIC microcontroller
i want to transfer data to Labview by the serial port RS232.
can anyone show me the way to represent this to signals at the same time in two differents diagrams?
i havemade an effort to represent this signals but the only thing i succed to do was to represent only one of them...
10-01-2008 05:21 PM
10-04-2008 04:50 AM
thank you for the responce.actually i did a simple vi via example basic serial read and write.
i add a converter from ascii to decimal because pic communicate labview by strings and not with numbers
also i add a simple plot just to see how it represent the bytes from pic to labview.
it seems to work but my problem is how can i save some data to labview (from pic)
i want to send a value and store it (Volt) and then another value(Ampere) and
present this values anytime i want in two different diagrams.
10-06-2008 06:12 PM
