I am performing a 8-channel(analog input)and 2-channel(analog output)triggered simultaneous AI-AO using PCI-6052E card.
My program had AI Confing, AI Start, AI CLear, AO Config and AO Clear VIs inside a while loop.I was told that since I was using software trigerred approach it would miss some pulse triggers.I was told to go for the following approach:
"The best way to go about that is to have a hardware timed system controlling the trigger pulses. To accomplish that, you will need to use both general purpose counters of your DAQ board."
"You will have the first counter configured as retriggerable pulse generation and the second counter as pulse train generation. Then, you connect the external trigger pulse to the first c
ounter gate, and its output to the second counter gate.
The you can use the second counter output as the AI Start Scan and AO Update pulses.
That will give you a trully hardware timed operation."
I did not understand how to do this.I have two counter output pins but I don't know how to connect the external trigger pulse to the first counter gate, and its output to the second counter gate.
As of now I am connecting the trigger pulse to PFIO pin.
urgent help needed.
thanks,
-shiv
