03-19-2014 07:32 AM
I need help with my data acquisition using fpga cRio 9072. I am relatively new to labview and i started with "NI 9323 Getting Started" vi and i managed to acquire data from my 9232 module, using fpga. The problem is that when i try to plot the data, on the OY axis i have voltage ( and this is ok) but on OX axis i have the sample number, instead of time. My data is like in [1] and i would like it to be similar to the one in [2]. I do not want to have on the ox axis the absolute time (time and date) but more of a relative time that resets to 0 each time the acquisition starts.
I would appreciate your help,
Valetina
04-05-2014 06:45 AM
can you attach the fpga vi code where you read the data and also the RT vi code where you display the data on graph. i want to ask some questions as follows;
1 do you used FIFO to transfer data between target (fpga) and host (RT) ?
2 do you used waveform generation vi (its attributes are Y , dt and t0) ?
05-30-2014 02:36 PM
Hello Tirmizi
I managed to solve that problem. Your tip nr. 2 was of great value, thx a lot!
I now have another problem that i deal with for a long time. I posted it here: http://forums.ni.com/t5/Real-Time-Measurement-and/cRio-FPGA-read-1024000-samples-and-transfer-to-RT/... I would appreciate if anyone could help...
