02-02-2021 09:45 PM - edited 02-02-2021 09:49 PM
I have a system that will be remotely deployed and will be gathering data from various sensors. The chassis I'm using is a 9041 and I have developed an application using the daqmx libraries to do the data acquisition (I've only done minimal FPGA coding).
This works great, but now I need to incorporate a gps module (9467) to timestamp the data and get the lat/lon/ele data.
I looked at the 9467 examples in the Help system, and they are both for FPGA targets. So I have two questions...
1) is it possible to interface with the 9467 using the RT Target and daqmx, or do I have to redo everything in FPGA?
2) if it's possible...is there an example or tutorial about how?
J
02-04-2021 02:00 PM
I can answer my own question. Might be helpful to someone new to this with the same question
yes you can use the 9496 running in FPGA with a daqmx program running on the RT target. This is the basic proceedure...
