08-30-2018 01:52 AM
cRio status led flashes every 10 sec.
cRio 9076
MAX doesn't see rio, but I can ping it from windows Command Prompt.
08-30-2018 12:13 PM
Have you seen the Status LED section in the user manual?
http://www.ni.com/pdf/manuals/375650d.pdf
It should be blinking at least twice in short succession.
Have you tried putting it in safe mode (procedure described in the user manual?). Is your host computer on the same subnet? Can the host see other CRIOs?
If none of that helps you, you might want to open up a service request as this might be an issue with just that unit.
08-31-2018 12:43 AM
I tried to reset it in save mode like it described in manual.
When the reset button is pressed, status led is continuously on, after releasing reset button, nothing changed, the status led blinks every 10 or 12 second.
I have tried this device with different computers, with different cRio versions.
Can it be physically damaged because of high voltage ? how can i check it ?
