12-11-2008 03:19 PM
I am using a cRIO 9004. I noticed that it has a chassis Temperature option. I was wondering if there was a way to find the input voltage. My device is battery powered and would like to know my batery voltage level. I am trying to make some sort of a brownout detector.
I am a novice at Labview - I am sorry if I have missed something obvious.
Thank you.
Solved! Go to Solution.
12-12-2008 10:57 AM
You haven't overlooked anything. There is currently no Chassis I/O set up to read the voltage on your input power. What you would have to do is use an analog input module to read the voltage yourself.
