09-03-2008 02:08 PM
I wanted to know how "solid" is the cRIO internal power regulation. I'm using the cRIO-9012 with NI 9505 modules witch are using their own power supply. I usually like to separate DC motor power supplies and controller power supply for better noise immunity. But now I’m facing the problem of having to cut cost and am thinking of using just one 24VDC power supply for the cRIO and the motors. Do you see any problems in doing so.
thanks
09-04-2008 11:16 AM
Hi MikeLaw,
The CompactRIO you have can operate in a range of 9 - 35V so as long as you do not exceed the current rating of your power supply (considering motors and cRIO) you should not have any problems.
09-04-2008 12:45 PM
MikeLaw, here is a related thread where someone is running into problems with a cRIO when a motor nearby is started/stopped.
http://forums.ni.com/ni/board/message?board.id=280&message.id=4211&query.id=42043
09-04-2008 12:53 PM
09-04-2008 03:21 PM
The only other thing I can add is that I have shared the power suppy of one cRIO Controller with other cRIO controllers as well as with some modules that require external power (digital modules) and haven't run into problems. Hope somebody out there has already tried what you want to do and can provide some input.
I guess as Eli_S said, if your power supply can keep up with the load you should be fine.
