Hi all,
today, for the first time, I wanted to deploy my RT project with SoftMotion Axis to cRIO. I encountered 2 issues that I am unable to resolve.
1. Issue is this:
I am not sure how to handle this. On the internet I read to resolve it I should Deploy All but I have some VIs that I do not want to be deployed at this time and are not needed to run program I want to deploy.
2. issue:
After pressing Apply on the 1st issues, deployment starts but at the end I get this error.
I spent good amount of time investigating what could be the problem. I can easily deploy project without SM Axis and it works, so I suppose problem could be the axis (tried to create example project with axis and got the same issue).
As a reference you can see all the SW installed on cRIO.
We are using LV 2017 x32.
Thank you for all the help,
Matyas
