cRIO Module alias names
How can a scan mode cRIO module be copied to another target without loosing its channel name aliases?
Also, how can a cRIO chassis target be retargeted to an upgraded controller without loosing any configuration settings?
Thanks.
(2,902 Views)
sachsm,
It does not look like there is currently a way of doing this.  I will file a suggestion for this though, as it would make things much easier!
I'm not sure I fully understand your second question.  Are you talking about moving the 'Chassis' section under a controller to a new controller in your project?  It doesn't seem like the Chassis has many configuration settings at all.  I might not be fully understanding this question though.
Jared Boothe
Staff Hardware Engineer
(2,867 Views)
