07-12-2019 04:16 AM
Hello Community,
I have a question about the power management of the cRIO usb ports.
I'm using the cRIO-9034 for the RT test bench and one of the requirement is to swith on/off the power of usb port to stress the external device.
I try to found the query that I can set to the command ligne in my RT app that will enable/disable or power on/off a usb port.
Actually I'm blocked because in the std Linux distribute I have an acces to this path :
echo disable > /sys/bus/usb/devices/usb1/power/wakeup
and then I can
echo on > /sys/bus/usb/devices/usb1/power/level # turn on
echo suspend > /sys/bus/usb/devices/usb1/power/level # turn off
But the RTOS of my cRIO hasn't the "power" folder. I've tried to change the value of bMaxPower file (default it is 500mA) but I have no permissions.
Today I have no idea is it possible to do without any external device.
08-23-2019 02:45 PM
Have you tried changing the permissions of the bMaxPower file? Try calling a chown with your user name on that file.
08-26-2019 03:31 AM
Yes, I've tried it also.
The problem is that the folder with bMaxPower (that influence the connection) not exists before the connection of the external device (port definition, etc). When I connect the device, It creates with the default parameters and when I change the value it is not instantly applied. If I restart the cRIO the default value is in place.
Finally I see that the Linux RTOS of cRIO has too much restriction, I will use the DO of the NI c-series module to drive directly the power of external device or to drive the external USB digital switch based on transistor switch.
