10-25-2011 11:08 AM
Hi I am using cRIO to measure Voltage in the renage of 0 to 10 V using 9239 module.
Everything runs fine and gives correct results, except when channels are swapeed, which can be seen on VI user interface.
I have attached picture with this, front panel with FPGA Target is the right order. Test 4 is windows side which has swapped channles.
Thanks in Advance.
10-26-2011 01:33 AM
As they say a picture paints a thousand words !
but a block diagram does help !
xseadog
10-27-2011 12:16 AM
What do you mean when channels are "swapped"? What channel are you using when you receive the correct data? and the incorrect data? What cRIO are you using? Could you post a screen shot of your block diagram?
Jordan
