08-20-2019 06:43 AM
Hi everyone.
There was a problem connecting the monitor to 9082. VI are not displayed on the local monitor under any settings. Only the initial console commands and processor load are displayed.
During the search, I was not able to find a document or any other information that allows me to understand this issue.
Perhaps you can tell me where to find instructions or an example.
Solved! Go to Solution.
08-21-2019 02:03 AM
Do you have cRIO-9082 with Real-Time OS? If so, you create VIs on your Windows PC and deploy it on cRIO. Real-Time OS does not have user interface, so it does not display your VI.
08-21-2019 02:16 AM
Yes, I use a real-time system and partially FPGA. Apparently, this structure cannot be displayed.
In this case, what exactly can be displayed on the local monitor?
I would like to see some example.
08-22-2019 10:48 AM
08-22-2019 10:57 AM
Well, apparently a similar option will only be available to me at 9039.
Although I do not fully understand why to equip the 9082 port for a monitor, if it is fundamentally impossible to connect it.
Anyway, thanks for the help.
08-22-2019 07:36 PM
The monitor ports for 9082 is there for 2 reasons. One is because there is a Windows variant of cRIO-9082, and for that you can connect the monitor to see the Windows GUI. For RT variant, you use the monitor to look at debugging texts. RT variant is intended to work headless.
