Reply
cRIO 9066 NIC Addressing Type Mysterious Reset??
I received a call from a customer who was unable to connect to their cRIO 9066 chassis over Ethernet (default) so I went to their location to investigate.
When I arrived, I was unable to connect to the chassis over the primary NIC using MAX, pinging the chassis, WIF, and, LabVIEW using the last known STATIC IP address. I ended up connecting via the USB port to discover that the chassis had its primary NIC addressing type set to DHCP, not the expected STATIC type. I reset the addressing type and the address to what it should have been and all is well.
My question is this - Is there anyway that the cRIO RT could have reset its primary NIC addressing type from "static" to "DHCP" without user intervention? I have dealt with these chassis for a very long time and this is a first for me. There are no switches other than the "Reset" switch, so an IP RESET could not have been performed. The chassis was not in "safe-mode" when I arrived. Actually, everything appeared to be operating normally other than the WIF and MAX couldn't see the chassis.
I am considering using the ".local" address for the chassis in case this happens again, but I am unsure if that would work if the host and cRIO are addressed on separate sub-nets.
Sincerely,
STUMPED
(872 Views)
Hello Drew,
I looked into the getting started guide for the cRIO 9066, and on this page it looks like the cRIO initiates a new DHCP connection on start-up, or if the reset button is held down for 5 seconds (on next page).
(842 Views)
Thanks for the information. I asked the customer if it was possible the reset button was long pressed twice.
(836 Views)
Highlighted
This seems like the likely cause. Otherwise, I'm not sure why it would change to DHCP mode.
(831 Views)
