I received a call from a customer who was unable to connect to their cRIO 9066 chassis over Ethernet (default) so I went to their location to investigate.
When I arrived, I was unable to connect to the chassis over the primary NIC using MAX, pinging the chassis, WIF, and, LabVIEW using the last known STATIC IP address. I ended up connecting via the USB port to discover that the chassis had its primary NIC addressing type set to DHCP, not the expected STATIC type. I reset the addressing type and the address to what it should have been and all is well.
My question is this - Is there anyway that the cRIO RT could have reset its primary NIC addressing type from "static" to "DHCP" without user intervention? I have dealt with these chassis for a very long time and this is a first for me. There are no switches other than the "Reset" switch, so an IP RESET could not have been performed. The chassis was not in "safe-mode" when I arrived. Actually, everything appeared to be operating normally other than the WIF and MAX couldn't see the chassis.
I am considering using the ".local" address for the chassis in case this happens again, but I am unsure if that would work if the host and cRIO are addressed on separate sub-nets.
Sincerely,
STUMPED
