cRIO 9055 General Use Question
Hello all,
Recently I've been working with a cRIO 9055 and I'm not entirely sure about how it's meant to be implemented.
To clarify, I've looked over different tutorials \ forum threads \ user manuals \ etc., but I can't seem to figure out if there's a way to directly connect a monitor to the cRIO itself (along with other devices such as a mouse and keyboard), or if a host computer is effectively necessary in order to operate it.
For context, the project I'm building requires the cRIO run in a hybridized mode with FPGA modules and a real time scanning module operating simultaneously. I was trying to better understand if I could simply deploy the code to the cRIO, have it launch an application on start up, and then work with it using a mouse \ keyboard \ monitor all directly connected to it versus needing a host computer to monitor the software execution.
I was originally thinking that the console port out would be able to provide a display, but the more I've read through the manual - that just seems to be an option to connect to a host PC so someone could make configuration changes there.
The host port also seems like it's just a way of adding peripheral USB devices like storage, a keyboard, etc.
Perhaps I'm misunderstanding something? I'm referencing this manual below:
https://www.apexwaves.com/pdf/manuals/cRIO-9056/cRIO-905x-User-Manual.pdf
Any help would be appreciated.
(508 Views)
Accepted by topic author Evan_Mi
There is a feature known as the embedded UI, but unfortunately not supported on cRIO-905x.
Which NI Real-Time Targets Support Embedded UI?
While cRIO-905X models do have x64 chipsets, these specific models do not have integrated graphics so embedded UI is not an option on these targets.
(493 Views)
