I have a LabView project to run some tests of a UUT. I have implemented the test on a cRIO 9053.
For test automation I will use TestStand and run the VIs on the cRIO via VI Server. Is that possible without having LabVIEW development environment running and the VI deployed?
I have:
LabVIEW2020
TestStand 2019
LabVIEW Real-Time 20.0.0
Activated the VI Server on the cRIO.
I have build a Source Distribution and deployed it. Location /home/lvuser/natinst/bin
Added all files to Always Included.
Removed all checks for exclude.
Activated "Run VI on a Remote Computer" for the step in TestStand.
Added Remote VI Path: /home//home/lvuser/natinst/bin/my.vi (this I'm not sourer if it is the correct path or typed correct?)
Works fine if I have LabVIEW environment running and the VI deployed (Remote VI Path: my.vi).
But when I'm not running LabVIEW and try VI Path: /home//home/lvuser/natinst/bin/my.vi I get:
"Failed to load VI on remote host."
"/home//home/lvuser/natinst/bin/my.vi"
"LabVIEW: (HEX 0x3EC) The VI is not in memory."
"Error Code: -17600; Failed to load a required step's associated module."
Regards
