06-19-2019 12:25 PM
If I have either a cDAQ or cRIO controller running Linux RT that have DAQmx capability, can I use either USB or Ethernet cDAQ expansion chassis?
e.g. can I use the cDAQ-9133 or cRIO-9045 with either the cDAQ-9178 (USB 2.0), cDAQ-9179 (USB 3.0) or the cDAQ-9189 (Ethernet)? Or some combination of those? Is there an advantage to USB vs. Ethernet? I'd lean towards USB thinking that it may be more robust.
Thanks.
06-20-2019 11:28 AM
You can use either chassis plugged into your controller as can be found here:
Adding Additional Slots to CompactDAQ Chassis
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004AvUSAU&l=en-US
USB has less latency but Ethernet allows you to connect remotely, it all depends on what is more important to your application.
09-23-2019 08:39 AM
Does this same KB also apply to the DAQmx enabled cRIO's? (both usb and ethernet?)
