cDAQ DAQmx Analog Output Waveform change of data is very slow
Hello there,
I am using a cDAQ 9189 with a NI 9263 outputting analog voltage waveforms (sine waves). The software we are using is self-written in C++ using the DAQmx C library.
The user of the software is supposed to change some parameters of the sine wave. The update of that should be as fast as possible. But with the way, I implemented it needs several seconds to take the new values over. I am using the following code to initialize and write to the AO port:
//Init
DAQmxCreateTask("OscillationTask",&oscillationTask);
DAQmxCreateAOVoltageChan(oscillationTask,NIDaqAdress[0].toLocal8Bit().constData(),"",-10.0,10.0,DAQmx_Val_Volts,NULL);
DAQmxCfgSampClkTiming(oscillationTask,"",numSamples*f,DAQmx_Val_Rising,DAQmx_Val_ContSamps, numSamples);
DAQmxRegisterDoneEvent(oscillationTask,0,DoneCallback,NULL);
//Create data
int numSamples = 1000;
int phaseN = 0;
int i = phaseN;
QVector<float64> dataRef = QVector<float64> (numSamples);
int PI =3.1415926535;
double offset = 0.;
            for(;i<(numSamples+phaseN);i++){
                dataRef[i-phaseN] = amp*sin((double)i*2.*PI/numSamples)+offset;
//Write data
    float64     data[100000];
    memcpy(data, dataRef.constData(), numSamples*sizeof(float64));
DAQmxWriteAnalogF64(oscillationTask,numSamples,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL);
//When I want to change something I use again:
//It is executed super fast but takes several seconds to see a change at the output
The last function is used for changing the waveform during runtime. It is working fine but needs several seconds to see a change at the analog output. Do somebody maybe have an idea how to optimize this?
Best
Florian
(1,805 Views)
Hi florian.vollrath,
I know this post has been open for a little while. You may have more success reposting this in the Multifunction DAQ forums, as this is forum is for Real-Time systems like cRIO and LabVIEW FPGA.
C. Weeks
Product Support Engineer
NI
(1,745 Views)
Thanks for the hint, I just did 🙂
(1,739 Views)
