Write to file in myRio
Highlighted
Hi,,
my code connot write data from myrio to my PC, I need you help to fix it. Plz,,
Message 1 of 12
(5,137 Views)
Highlighted
The myRIO doesn't actually run on your computer.  It has its own OS and file system.  Would you expect your friend's computer to write to your computer's harddrive?  Well, it can if you use a shared folder and address the folder with the network name.  So you need to supply a network address for your shared folder on your system that the myRIO can then write to.
GCentral
Message 2 of 12
(5,130 Views)
Highlighted
Thank you for your reply and help
actually , I just need write  data on file  when I run the system.
Message 3 of 12
(5,128 Views)
Highlighted
I don't understand what you mean by this.
GCentral
Message 4 of 12
(5,125 Views)
Highlighted
I mean my code cannot wirte data to file
Or the wirte to file box not working with myrio
Message 5 of 12
(5,118 Views)
Highlighted
Write*
Message 6 of 12
(5,117 Views)
Highlighted
Again, the myRIO is its own little computer.  Anything that you run will be ON THE MYRIO.  The myRIO doesn't have a GUI.  So you need to supply the file path manually and you need to give it a network address if you want it writing to your harddrive.  Otherwise it tries to write on its own flash drive.
GCentral
Message 7 of 12
(5,115 Views)
Highlighted
I see.
So, could you give me an example code for write data on myrio drive.plz
or any helpfull link.
Thanks alot
Message 8 of 12
(5,112 Views)
Highlighted
Here's a couple of articles to read:
Under the Hood of NI Linux Real-Time
Working with File Paths on Real-Time Targets
GCentral
Message 9 of 12
(5,104 Views)
Highlighted
Message 10 of 12
(5,098 Views)
