Tom,
The latest version of NI-DAQ right now is NI-DAQ 6.9.1, which comes with MAX 2.1. If you don't have that, you can download it from the http://www.ni.com/download pages. If you are upgrading from a previous version, make sure to completely uninstall the previous version (NI-DAQ and MAX) before installing the new one.
Once NI-DAQ is properly installed and your RDA boards and virtual channels are set up, you can use them in LabVIEW. When making calls to a remote board via RDA the input REQUIRES the correct device number in order to execute. It's allowed for the local computer to have a channel with the same name as a remote channel. Thus, by design, the user must enter the device number of the remote device when using its channels.
This is related to Kno
wledgeBase 1N9BFOHQ: "Error -10001 When Using Virtual Channel and Remote Device Access (RDA)". You can find this entry when you go to the http://www.ni.com/support page and choose KnowledgeBase from the Technical Resources pulldown menu. Then, type in search keywords, such as "virtual channel and RDA".
So, the trick is to just add that device number, and then you can read the scaled values!
Geneva L.
