I am doing my research on motion control for three phase inducton motor.Where i am designing a DTC core( an algorithim implemented in VHDL / Xilinx software for motor control). The DTC core consists of seven different blocks and it is about 2500 lines VHDL code. i am try to implement this core in LabVIEW/ FPGA / CompactRIO hardware . I am using HDL interface node for each block.Finally each blocks are inter connected.
Problem faced during writing VHDL code in HDL interface node:
1. How to write GENERIC syntax e.g.
generic(N:integer:=8);
since we can not entry any code in ENTITY.
2. If i am declaring a variable e.g.
for i in N-1 downto 0 loop
if (A(i) < B(i)) then
LESSER <='1';GREATER<='0';EQUAL<='0';
exit; ,
FPGA Complier is not understanding , What is N.
3. In HDL Interface node there is a option EXTRNAL FILE, What does it mean. Attaching external VHDL file or any other files.
4. Please try the following example using cRIO. This program is running sucessfully in Xilinx software but not in LabVIEW FPGA.
VHDL Code for comparator circuit
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity comparator is
port(A,B:in std_logic_vector(N-1 downto 0);
EQUAL,GREATER,LESSER:out std_logic);
end comparator;
architecture RTL1 of comparator is
begin
P1:process(A,B)
begin
exit;
elsif (A(i)>B(i)) then
GREATER <='1';LESSER <='0';EQUAL <='0';
exit;
elsif (A(i)=B(i))then
EQUAL <='1';GREATER <='0';LESSER <='0';
exit;
end if;
end loop;
end process;
end RTL1;
thank you
sahoo
sarat
