From 02:00 AM CST Saturday, February 4 - 06:00 AM CST Saturday, February 4, ni.com will undergo system upgrades that may result in temporary service interruption.
09-07-2015 06:13 AM
Hi
I will use sbrio for control of step motor therefore i need step motor shield .i searched aboud shield ardunio motor sheild and which i shıuld step motor shield with work sbrio?
Thank you
09-08-2015 05:04 PM
Hi osman87,
While some of our hardware has a shield board (such as the myRIO), the sbRIO does not have a prefabricated option for connecting stepper motors or arduino shields.
You can use the DIO pins of the sbRIO to generate a pulse train for the stepper, however please note that these DIO lines are not powerful enough to driver a stepper motor.
Kind Regards,
09-09-2015 01:24 AM
Than you for answered.
09-09-2015 09:53 AM
If you want an off-the-shelf solution for driving stepper motors from sbRIO, you could consider adding C Series modules. This would require using an sbRIO that includes the RIO Mezzanine Card (RMC) connector, such as the sbRIO-9627 rather than the 9637. The NI 9503 is a stepper drive C Series module. You would also need to purchase the NI 9693 C Series RMC to adapt the sbRIO to connect directly to C Series modules.
Recommended components
NI 9503 Stepper Motor drive module
NI 9693 2-slot C Series RMC for sbRIO
sbRIO-9627 Multifunction IO sbRIO with RMC
The same NI 9503 module would also work well in any CompactRIO controller without any extra adapter RMC, such as the entry level cRIO-9063. For a similar price, the cRIO-9063 is about 4x more performant than the sbRIO-9637 and can support up to 4 C Series modules. The biggest tradeoff is the cRIO-9063 does not include the integrated analog IO circuitry.
09-14-2015 01:41 AM
Thank you for advise.I will try.
10-09-2017 09:10 AM
@Spex,
Is there option to use sbRIO to control at least 4 step motors? I also want to have some DIO too.
Thanks.
10-09-2017 12:48 PM
10-09-2017 12:55 PM - edited 10-09-2017 12:56 PM
Currently, my company uses 9030 (4 slots) for 3 9503 and 1 9421. We have to use another micro-controller boar to control another pair of small step motor by usb port. We have problem with that micro-controller board, so I am looking for option to extend the module to control more step motor. We cannot use CRO 9067 because of the limited space in our instrument. That's why I am looking for option with sbRIO.
10-09-2017 01:48 PM
You can either design your own mezz board for the sbrio or maybe find a small motor controller that takes commands over RS485/ethernet/etc. NI mentions some here.
