Which PCI and PCIe connectors with PCIe-7852, PCIe-6351 and PCI-6733
Hi there,
I am looking for a PC motherboard to house all three NI cards: PCIe-7852, PCIe-6351 and PCI-6733. However, I am unable to find the type of PCI and PCIe bus connectors these boards come with (unless I am completely blind to what the spec sheets say), and as a result I don't know which motherboard with PCI and PCIe bus slots would be suitable.
My guess (by visual inspection) for the PCIe one would want a x1 PCIe slot for each aforementioned PCIe board and a conventional PCI slot for the PCI-6733. If I understand things correctly, the conventional PCI bus is 32-bit, so is there a way to convert it?
Any feedback on this would be greatly appreciated.
Thanks.
Nevermind, I managed to figure it out.
The PCI slots are standard, so there is no need to change anything.
The PCIe slots for the PCIe cards are compatible with the x1 PCIe bus slot ( can be found in http://www.ni.com/datasheet/pdf/en/ds-100 under "Native PCI Express Interface")
Message 1 of 1
(2,233 Views)
